Monitoring AKKA based Applications
vikas_pathak
Newcomer
Hi, we are using AKKA based application that routes requests to downstream Engine. Does dynatrace support AKKA framework?
3 REPLIES 3
michael_breen2
Newcomer
Hi Vikas,
You could start off by looking at the link below:
https://www.dynatrace.com/technologies/java-monito...
In short, the answer is yes.
vikas_pathak
Newcomer
Thank you Mike.We tried hooking Dynatrace without instrumenting any methods.Response times spikes up with Dynatrace enabled. Tried same volume without Dynatrace and we were able to run a successful test.
michael_breen2
Newcomer
Ok, that sounds like something which should not happen. I would recommend passing a question to support about that and let them investigate what's going on. I have not experienced these type of issues with agent so far.
