What is the logic in the problem numbering
henk_stobbe
DynaMight Champion
DynaMight Champion
I received in the mail:
problem 902, number 443 and after that number 166
Is there a reason or logic behind this numbering?
Radoslaw_Szulgo
Dynatrace Guru
Dynatrace Guru
It's a simple incrementation. You just need to keep in mind that once a problem is created it's ID is persisted. If the problem reoccurs, it has the same ID.
Senior Product Manager,
Dynatrace Managed expert
