Is it possible to look at the raw logs with the oneagent log analyzer?
tarjei_utnes
Organizer
I am not able to find this anywhere in the documentation.
3 REPLIES 3
pawel_brzoska
Inactive
If you are talking about Dynatrace Log Analytics, it can support any text file with understandable date/time format. I'm not sure if that matches your definition of raw log, please provide more details if not. You can also download the actual file and look inside using any external text viewer.
tarjei_utnes
Organizer
Ok, but what I am looking for is to be able to see each line of the log file in Dynatrace. Is that possible?
For example the Windows Event seems to not contain the information I am after.
pawel_brzoska
Inactive
Yes, each log line is available for analysis. Windows event logs are also supported, you can find them (System, Security and Application Logs) in host pages. Also IIS logs written to these logs are available from IIS process pages. All logs collected are visible and available for analysis in Log Viewer available from left side menu's "Log files" entry.
