Amazon Redshift
kevin_leng
Dynatrace Organizer
Dynatrace Organizer
Hi all,
Can anyone tell me if we have support for Amazon Redshift? If not, is it on the road map?
Cheers Kev.
3 REPLIES 3
Karolina_Ruszko
Inactive
Hi Kev,
We do not have CloudWatch integration for Redshift at the moment, however it's on the roadmap. Meanwhile you could use custom metrics API to push Redshift metrics to Dynatrace cluster. Here are some details:
https://help.dynatrace.com/dynatrace-api/custom-devices-and-metrics/what-does-the-custom-network-devices-and-metrics-api-provide/
Best,
Karolina
michael_kopp
Dynatrace Champion
Dynatrace Champion
The DB Service side of things will work. As long as the application that uses Redshift is fully monitored you will see all statements, response times, errors and more.
RedShift is based on postgres and will usually show up as such when used by a monitored application. The jdbc driver is also supported and it will show up as Redshift.
Best
Mike
michal_nalezin
Dynatrace Advisor
Dynatrace Advisor
Hi Kev
Metrics for Amazon Redshift are available in the EAP for AWS supporting services. The EAP provides access to CloudWatch metrics for 11 preselected services.
Best
Michal
