While testing API with Postman getting below error, please help. I am using token also(generated from Dynatrace Saas).
The end point I am using is ---
https://{xxx}.live.dynatrace.com/api/v1/timeseries/?apitoken=123456789
{"error":{"code":401,"message":"Unsupported authentication mechanism -> 'Basic', could not be used as fallback."}}
Answer by Suresh K. · Jun 09, 2017 at 11:58 AM
Hi Wolgang,
I tried with 'Api-Token=' as well but now I am getting Authorization is required for access to this proxy.
I specify the proxy with authorization still showing proxy problem.
Do I need to allow access to dynatrace server instance.
Answer by Wolfgang B. · Jun 09, 2017 at 12:54 PM
By the way I hope you did not post the real token here?
https://{xxx}.live.dynatrace.com/api/v1/timeseries...
Should be the correct and full request, that returns the list of defined metrics.
Answer by Suresh K. · Jun 09, 2017 at 01:17 PM
After applying the token I am getting below xml
<HEAD>
<TITLE>Proxy Authorization Required</TITLE>
</HEAD>
<BODY BGCOLOR="white" FGCOLOR="black">
<H1>Proxy Authorization Required</H1>
<HR>
<FONT FACE="Helvetica,Arial">
<B>
Description: Authorization is required for access to this proxy</B>
</FONT>
<HR>
<!-- default "Proxy Authorization Required" response (407) -->
</BODY>
Answer by Suresh K. · Jun 12, 2017 at 07:36 AM
Hi Wolfgang,
I got the desired response after accessing from my personal laptop.
While accessing from my client network I am not getting desired response as there are Firewall.
Do I need access to Dynatrace saas server instance to get the response.
Answer by Wolfgang B. · Jun 12, 2017 at 07:44 AM
I do not really understand your set up. You are running a Dynatrace SaaS environment, at least the domain you provided suggests that?
So your company firewall is blocking the access to Dynatrace SaaS server? How do you access Dynatrace SaaS Web UI then?
best,
Wolfgang
Answer by Suresh K. · Jun 12, 2017 at 09:25 AM
hi,
Yes this is dynatrace saas environment ,I am able to access the Web UI, but if a do a ping on https://{xxx}.live.dynatrace.com request time out . After ping to https://{xxx}.live.dynatrace.com it resolve to 2 IP Addresses which are dynatrace server IP. I tried telnet to those IP address which show connection failed. Does it mean that I don't have connectivity to dynatrace server.
Answer by Wolfgang B. · Jun 12, 2017 at 10:17 AM
I fear thats a firewall issue on your side, from our perspective there is not much difference between the Dynatrace Web UI and REST API except the additional /api/ subpath. Can you ask your firewall admin what they defined as rules to access Dynatrace SaaS domain?
Answer by Rejith R. · Jul 13, 2017 at 12:01 AM
I am getting the same error - Unsupported authentication mechanism -> 'Basic', could not be used as fallback !! In my case no firewall involved
Here is the URL I am trying
Learn the enhanced capabilities of the next generation Dynatrace AI root cause analysis and how to feed it with your own data sources.
Wednesday, February 20, 2019
Register today!
Register today!
Would you like to have an early taste of what we have cooked up for 2019? We would love to hear your feedback and improve some of the new features. Check NAM 2019 Beta release notes.
Sign up today!
