Generate CSR
henk_stobbe
DynaMight Champion
DynaMight Champion
I want to get my own certificates (for a Managed Environment), there are nice info about how to generate a CSR per platform type. What is the correct procedure for me to choose? And are there other things I should know about?
I found the documentation to install the certificate, but there is little info about above,
KR Henk
8 REPLIES 8
Radoslaw_Szulgo
Dynatrace Guru
Dynatrace Guru
Hi Henk,
In Dynatrace Managed we can set up a SSL certificate on your behalf and install it on all nodes and SGs. Is that sufficient to you?
Take a look at the Settings screenshot:
Senior Product Manager,
Dynatrace Managed expert
henk_stobbe
DynaMight Champion
DynaMight Champion
Hi Radoslow,
We have are own Dynatrace Managed installation, so we can not use the Dynatrace certificate. Sorry
KR Henk
how about this problem, has it been solved? I'm having the same problem.
Radoslaw_Szulgo
Dynatrace Guru
Dynatrace Guru
If you already have a certificate. Just download following files from you CA provider:
  • Server certificate (.cer or .cert )
  • Root and Intermediate certificates (.cer or .cert )
  • Private key for certificates (.pem )
And paste contents to the UI presented in Help.
If you don't have a certificate yet, then use OpenSSL toolkit to generate CSR and provide it to the CA you have selected in order to request a valid certificate.
I'm not sure if it's clear enough to you, but the automatic certificate that you can get for free from Dynatrace is a valid certificate, verified by CA (Let's Encrypt) - it's not the self-signed by Dynatrace.
Hello @Radoslaw S.
I wanted to generate a CSR certificate to use customer own CA certificate, therefore, let me know the procedure to generate the CSR and share with them.
Babar
henk_stobbe
DynaMight Champion
DynaMight Champion
Hi Radoslaw,
Our cluster has and url that will end with *.atos.net so the certificate *.dynatrace.com will not work (-; sorry,
KR Henk
in case you rely on dynatrace's certificates, we create a subdomain of managed-dynatrace.com for you + a valid certificate for that domain.
What's the issue you currently have?
Radoslaw_Szulgo
Dynatrace Guru
Dynatrace Guru
Afzal, do you need help with that? I can assist.
