Support of ADK for Java
raneesh
Newcomer
Hi all,
I hope this is a right place to ask the question.
Does dynatrace support AppMon ADK [Tagging ADK for java applications] so that it can be used for custom protocols instrumentation?
https://www.dynatrace.com/support/doc/appmon/integ...
If yes, is there any difference in using it?
TY
6 REPLIES 6
c_schwarzbauer
Dynatrace Champion
Dynatrace Champion
hi Raneesh,
we're currently in the process of building such an ADK also for Dynatrace.
it will be different from the AppMon ADK, but it will be more powerful and (hopefully) easier to use.
however, it will take us some more time to finalize and release it.
HTH, Christian
alexander_zagor
Advisor
Thanks @Julius L.
As I understand, neither Golang nor Python apps will get the support of the mentioned ADK?
Hello @Sun K., we have released a first EAP (early access) version of the OneAgent SDK for Python: https://github.com/Dynatrace/OneAgent-SDK-for-Python.
Looking forward to get your feedback!
chase_hulderma1
Inactive
@Sun K.What you're looking for is here - https://github.com/Dynatrace/OneAgent-SDK
sonja
Inactive
The OneAgent SDK for Java, Node.js and C/C++ has been released as a beta. We are looking forward to your feedback!
Documentation: https://www.dynatrace.com/support/help/extend-dyna...
Feedback Thread: https://community.dynatrace.com/spaces/483/dynatrace...
