Limitation on Frequency of a API call
suresh230591
Mentor
Hi ,
Is there any limitation on number of times we can call a API ( specially problem API) and how much data we can pull .
4 REPLIES 4
Radoslaw_Szulgo
Dynatrace Guru
Dynatrace Guru
Yes. 10 requests per minute. To increase that limit contact with a sales rep.
Senior Product Manager,
Dynatrace Managed expert
suresh230591
Mentor
Thanks Radoslaw,
I have one more question .
what is best possible way to send notification to 3rd part tool ( by API's or Webhooks) .
please advice
Radoslaw_Szulgo
Dynatrace Guru
Dynatrace Guru
Well... I'd check if one of our integrations work for you. For instance, I like the Slack integration (
https://www.dynatrace.com/technologies/integration...
Really, it depends what is your use case. If you share it, we are happy to help and recommend sth.
Check out what we currently support at: https://www.dynatrace.com/technologies/integratio...
suresh230591
Mentor
In our case we want to send the problem notification to 3rd party tool (not listed in the document).
I checked the webhook and Problem API document.
Can we get the information like number of users affected by that problem.
Can we add more fields in API or Webhook Json payload which is not in the document.
Is there any Limitation of amount of data pull through API.
