Is there a way to add users without setting up an SMTP server?
krokkas
Helper
6 REPLIES 6
Radoslaw_Szulgo
Dynatrace Guru
Dynatrace Guru
Hi Kyle,
we are working on it. Just enter a dummy value for the time you enter a valid one.
Senior Product Manager,
Dynatrace Managed expert
Radoslaw_Szulgo
Dynatrace Guru
Dynatrace Guru
Hi Kyle just an update - this has not yet been addressed in the product. This is not a simple case to solve as we need to help users to go right way - set up a valid SMTP server before inviting users.
I'll let you know when this is applied to the product.
daniele_danton1
Dynatrace Helper
Dynatrace Helper
Was this issue fixed, please? Facing same issue today. Have to deploy an offline cluster and apparently we can't create any users without an SMTP.
Not yet...
Being that this ticket is several years old, at this point I would recommend putting in a Request for Feature
-Chad
Chad, it won’t change anything... I know that this is here.
