Monitoring RabbitMQ?
raffaele_talari
Inactive
Hi there,
is it
possible to monitor a RabbitMQ (CloudFoundry service) queue size somehow?
If so, how? Would it be possible to pull queue size data using the DynatraceAPI?
Thanks in advance for your help,
Raff
3 REPLIES 3
Jakub_Mierzewsk
Inactive
Hi Raff,
We have RabbitMQ plugin which runs in OneAgent. If OneAgent can be installed on RabbitMQ host then we will have all metrics form plugin . If OneAgent could not be install then plugin will not work and API will be needed.
Best,
Jakub
raffaele_talari
Inactive
just to add some details about using Dynatrace API for RabbitMQ metrics, here's a quick guide.
Hope that helps.
Ciao,
Raff
Dynatrace API – RabbitMQ
For details about monitoring
RabbitMQ please refer to these pages:
https://www.dynatrace.com/blog/introducing-rabbitmq-monitoring-beta/
API Endpoints:
RabbitMQ timeseries API invocation:
https://{{Tenant}}.live.dynatrace.com/api/v1/timeseries
https://{{owndomain}}/e/{{Tenant}}/api/v1/timeseries
*remember
to always put the APIToken in the API invocations. That is generated in the UI
under Settings -> Integration -> Dynatrace API
All the
available API parameters here: https://help.dynatrace.com/dynatrace-api/timeseries/how-do-i-fetch-the-metrics-of-monitored-entities...
RabbitMQ timeseries API invocation examples:
Querying
the average size of the queues in the specified timeframe expressed in Unix
time milliseconds (useful link for UTC to milliseconds and conversion: https://currentmillis.com/)
https://{{Tenant}}.live.dynatrace.com/api/v1/timeseries?Api-Token={{ApiToken}}&timeseriesId=ruxit.python.rabbitmq:queues_count&startTimestamp=1492905600000&endTimestamp=1492992000000&aggregationType=avg
Available RabbitMQ metrics (timeseriesId=):
  • "ruxit.python.rabbitmq:ad_queues_no_consumers",
  • oAuto-delete
    queues without consumers.
  • "ruxit.python.rabbitmq:channels_count"
  • oThe
    number of channels (virtual connections). If the number of channels is high,
    you may have a memory leak in your client code.
  • "ruxit.python.rabbitmq:cluster_channels"
  • oThe
    number of virtual connections (AMPQ connection).
  • "ruxit.python.rabbitmq:cluster_connections"
  • oThe
    number of TCP connections to the message broker. Frequently opened and closed
    connections can result in high CPU usage. Connections should be long-lived.
    Channels can be opened and closed more frequently.
  • "ruxit.python.rabbitmq:cluster_consumers”
  • oThe
    number of consumers.
  • "ruxit.python.rabbitmq:cluster_exchanges"
  • oThe
    number of exchanges.
  • "ruxit.python.rabbitmq:cluster_messages_ack"
  • oThe
    rate at which messages are acknowledged by the client/consumer.
  • "ruxit.python.rabbitmq:cluster_messages_deliver_get"
  • oThe
    rate per second of the sum of messages: (1) delivered in acknowledgment mode to
    consumers, (2) delivered in n0-acknowledgment mode to consumers, (3) delivered
    in acknowledgment mode in response to basic.get, (4) delivered in
    n0-acknowledgment mode in response to basic.get.
  • "ruxit.python.rabbitmq:cluster_messages_publish"
  • oThe
    rate at which messages are incoming to the RabbitMQ cluster.
  • "ruxit.python.rabbitmq:cluster_messages_ready"
  • oThe
    number of messages that are ready to be delivered. This is the sum of messages
    in the messages_ready status.
  • "ruxit.python.rabbitmq:cluster_messages_redeliver",
  • "ruxit.python.rabbitmq:cluster_messages_return_unroutable",
  • "ruxit.python.rabbitmq:cluster_messages_unacknowledged",
  • oThe
    number of messages delivered to clients, but not yet acknowledged. This is the
    sum of messages in the messages_unacknowledged status.
  • "ruxit.python.rabbitmq:cluster_nodes_failed",
  • oThe
    number of unhealthy nodes. Please be aware that not every RabbitMQ version
    provides this metric.
  • "ruxit.python.rabbitmq:cluster_nodes_ok",
  • oThe
    number of healthy nodes. Please be aware that note every RabbitMQ version
  • "ruxit.python.rabbitmq:cluster_queues_crashed",
  • "ruxit.python.rabbitmq:cluster_queues_down",
  • "ruxit.python.rabbitmq:cluster_queues_flow",
  • "ruxit.python.rabbitmq:cluster_queues_idle",
  • "ruxit.python.rabbitmq:cluster_queues_running",
  • "ruxit.python.rabbitmq:connections_count",
  • oThe
    number of connections.
  • "ruxit.python.rabbitmq:consumers",
  • oThe
  • "ruxit.python.rabbitmq:disk_free_left_to_limit"
  • oThe
    percentage of available RabbitMQ disk space. Indicates how much available disk
    space remains before the disk_free_limit is reached. Once all available disk
    space is used up, RabbitMQ blocks producers and prevents memory-based messages
    from being paged to disk. This reduces, but doesn’t eliminate, the likelihood
    of a crash due to the exhaustion of disk space.
  • "ruxit.python.rabbitmq:fd_usage"
  • oThe
    percentage of available file descriptors. RabbitMQ installations running
    production workloads may require system limits and kernel-parameter tuning to
    handle a realistic number of concurrent connections and queues. RabbitMQ
    recommends allowing for at least 65,536 file descriptors when using RabbitMQ in
    production environments. 4,096 file descriptors is sufficient for most
    development workloads. RabbitMQ documentation suggests that you set your file
    descriptor limit to 1.5 times the maximum number of connections you expect.
  • "ruxit.python.rabbitmq:mem_usage"
  • oThe
    percentage of available RabbitMQ memory. 100% means that the RabbitMQ memory
    limit vm_memory_high_watermark has been reached. (by default, vm_memory_high_watermark is set to 40% of
    installed RAM). Once the RabbitMQ server has used up all available memory, all
    new connections are blocked. Note that this doesn’t prevent the RabbitMQ server
    from using more than its limit—this is merely the point at which publishers are
    throttled.
  • "ruxit.python.rabbitmq:messages_ready",
  • oThe
    number of ready messages.
  • "ruxit.python.rabbitmq:messages_unacknowledged",
  • oThe
    number of unacknowledged messages.
  • "ruxit.python.rabbitmq:node_status",
  • oThe
    status of the node.
  • "ruxit.python.rabbitmq:proc_usage",
  • oThe
    percentage of available Erlang processes. The maximum number of processes can
    be changed via the RABBITMQ_SERVER_ERL_ARGS environment variable.
  • "ruxit.python.rabbitmq:queues_count",
  • oRabbitMQ’s
    queues are most efficient when they’re empty, so the lower the Queued messages
    count, the better.
  • "ruxit.python.rabbitmq:sockets_usage",
  • oThe
    percentage of available Erlang sockets. The required number of sockets is
    correlated with the required number of file descriptors. For more details, see
    the” Controlling System Limits on Linux” section at www.rabbitmq.com.
  • "ruxit.python.rabbitmq:status-failed",
  • on/a
  • "ruxit.python.rabbitmq:status-ok",
  • on/a
  • "ruxit.python.rabbitmq:topN_queue_ack",
  • on/a
  • "ruxit.python.rabbitmq:topN_queue_consumers",
  • on/a
  • "ruxit.python.rabbitmq:topN_queue_deliver_get",
  • on/a
  • "ruxit.python.rabbitmq:topN_queue_messages_ready",
  • on/a
  • "ruxit.python.rabbitmq:topN_queue_messages_unacknowledged",
  • on/a
  • "ruxit.python.rabbitmq:topN_queue_publish",
  • on/a
API invocation of available metrics for Dynatrace Plugins:
https://{{Tenant}}.live.dynatrace.com/api/v1/timeseries?Api-Token={{ApiToken}}&filter=PLUGIN
hjamal21
Newcomer
Can anybody confirm if we need to restart the Rabbit MQ instances after the oneagent deployment?
