AWS API Gateway integration
rputhen
Guide
Is there a way we can get AWS API Gateway metrics like Invocations, 400, 500X Errors etc from cloudwatch to Dynatrace using custom API or any other way.
Ram
4 REPLIES 4
rputhen
Guide
@Andreas G.
Is there a way you can talk to Engineering and get this added to Product backlog, It would be really helpful if we can stats of AWS API Gateway & SQS as most of our Lambda are getting triggered from API Gateway and API Gateway is consumer facing so getting those stats will be really helpful.
Ram
pawel_brzoska
Inactive
Hi all, this is on the roadmap already, actually we are working on this currently. Any metric available in CloudWatch will have a possibility to be added to the UI. EAP is expected Q3/Q4.
josh_sinfield
Newcomer
Hi @Pawel B. The ability to inspect any CloudWatch Metric is very welcomed!
michal_nalezin
Dynatrace Advisor
Dynatrace Advisor
Amazon API Gateway is available in the EAP for AWS supporting services, that provides access to all CloudWatch metrics for 11 preselected services.
You can ingest API Gateway metrics like 4XXError, 5XX Errors, CacheHitCount, Latency, etc and monitor them in Dynatrace.
Best
Michal
