Does DT SaaS support Brocade virtual traffic manager?
ianmolynz
Inactive
Community Team
Community Team
Hello Ian,
On this documentation page, you can see all environments, technologies, and versions that can be monitored with Dynatrace:
https://www.dynatrace.com/support/help/shortlink/supported-technologies
Brocade virtual traffic manager isn't on this page, so as far I know, it is not supported at this moment.
If you have any questions about the Community, you can contact me at maciej.neumann@dynatrace.com
dave_mauney
Dynatrace Champion
Dynatrace Champion
If it is used basically as a load balancer, it should be picked up as a proxy and if there are agents on either side, I would expect the PurePath to continue from one to the next as long as our tracking header is not dropped.
