Dynatrace SaaS - Webchecks (clickpath) on a site internal
fernando_albuqu
Organizer
Is it possible to use webchecks (clickpath) on a site internal to the company (not released for the internet)?
I know that in dynatrace synthetics this is possible, but I wonder if it is also possible in the dynatrace SaaS.
Thank you all,
Fernando
3 REPLIES 3
Philipp_Kastner
Dynatrace Pro
Dynatrace Pro
Hi Fernando,
currently that's only possible if you include our web check location IPs in your firewall configuration. You can find the IPs during the creation of a web check and also if you edit it.
Additionally, we are currently working on HTTP checks which will allow you to monitor availability of internal applications with simple HTTP requests from within your network.
Kind regards, Philipp
When will this be available or is it now?
fernando_albuqu
Organizer
Thank you Phillipp.
