question
Ian M. avatar image
Ian M. asked ·
Dashboard Letter Color
Hi, In DynaTrace Saas is there a way of specifying the background color of the letter that identifies top level dashboards? Currently it seems pretty random or is there some logic behind the default background color selection?
dashboarddynatrace saasgui
1 Answer
Roman W. avatar image
Roman W. answered ·
Hi Ian! The avatar color for a dashboard is calculated through its internal id. This is done so you can visually distinguish dashboards from each other. There are no plans to make this configurable at the moment.
Share
