How problem notification works for Availability
suresh230591
Mentor
I have deployed OneAgent extension on my Azure VM. I stopped the VM for 10 minutes but did not get any notification in the problem pane.
Can anybody know on what basis problem defined. I checked the anomaly detection threshold but could not find anything related to availability.
One more thing I have just noticed, I am unable to find default infrastructure thresholds in Anomaly detection.I am using recent release.
wolfgang_beer
Dynatrace Leader
Dynatrace Leader
Dynatrace does only report an availability problem in case real user traffic is impacted. But in case you would like to opt-in and force Dynatrace to report the unavailable state of any process you can do so within the process specific 'Anomaly detection' settings (See my screenshot). Reason for that is that we would like to avoid problem spamming for unimportant processes.
Your second question is related to a bug that was immediately fixed and already shipped into production through a hot fix. The entire settings page should be available within the next hours.
Best,
Wolfgang
