Tracing process packet retransmissions
steven_francis
Participant
Dynatrace is reporting high process packet retransmissions, how can I investigate this further ? Our network team can't seem to see anything untoward, but perhaps I need to guide them to look in a more specific area ?!
JamesKitson
Dynatrace Guru
Dynatrace Guru
I don't have much experience in this area as to where to look but this page goes into a bit of detail on that metric: https://help.dynatrace.com/problem-resolution/root...
James
hayden_miedema
Inactive
James provides a good article to check out for some more info on the problem.
An option, and I'm not sure if this is viable, would be to use Wireshark on the server that is having high retransmission rate. Then analyze the port that is being used for the retransmission traffic. Wireshark link: https://www.wireshark.org/
Your network team may have already done this or looked into it, but doing it yourself (if possible) could give you some helpful ammunition in leading them to the problem
Hayden
