Using URL parameter for user tagging
tarjei_utnes
Organizer
We have a solution that has the username of the users in one of the calls in the login process. Is it possible to tag the user session with this information?
5 REPLIES 5
tarjei_utnes
Organizer
This is for Dynatrace Managed / SaaS
Ah sorry, I've not seen that. Then it's not possible yet unfortunately. I suggest posting an RFE like Alexander suggested below.
Dynatrace Certified Master, AppMon Certified Master - Dynatrace Partner - 360Performance.net
Mike_L
Dynatrace Guru
Dynatrace Guru
Hi Tarjei,
This is not (yet) possible. The current options for user tagging are these (on top of doing it using the JavaScript API):
You can find the options under "User tags" in the application settings.
Please create an RFE, it sounds like a good feature.
Mike
Mike
AlexanderSommer
Dynatrace Champion
Dynatrace Champion
At the moment this is not possible. But the use case is valid. Can you post your idea with a sample in out product ideas forum? You can than track the idea.
https://community.dynatrace.com/spaces/483/view.html
tarjei_utnes
Organizer
I created a RFE for this
