Hi
Prospect has a proxy that uses their own certificate for connections from their LAN to the Internet and they are asking if there is a way to add this certificate to the DynaTrace Managed communication with Mission Control?
Yos @Gil G.
Answer by Radoslaw S. · Oct 09, 2017 at 07:24 PM
Do you mean that the prospect can only communicate with external services in the internet that has their own certificate? Sounds very unique..
Or just they have a proxy server with a certificate? In that way I see no issues.
Can you please specify? The easiest way to verify if it works is to send HTTP GET request to Mission Control from a host where cluster is/will be deployed.
See our help page (https://help.dynatrace.com/dynatrace-managed/dynatrace-server/which-network-ports-does-dynatrace-server-use) :
Dynatrace clusters must be able to communicate to Mission Control (IP addresses 52.5.224.56
and 52.200.165.10
, 52.221.165.63
, and 13.228.109.33
) via HTTPS (port 443
) for license validation, health monitoring, and automatic updates. This communication can be routed via a proxy, but the proxy must allow web sockets and, if the proxy is clustered, it must provide sticky sessions for web socket communication.
Hi Radoslaw,
This is a health care system and as so they only allow outbound communication to the internet with using their own certificate throw their proxy.
For the POC they allow the connection without the certificate but its look like that this will be an issue later on.....
Yos
Answer by Radoslaw S. · Oct 10, 2017 at 05:42 AM
You need to check it. Anyway, there are settings in CMC to specify proxy address that is used to connect to Mission Control.
Hi Radoslaw,
First of all thanks for your help
And for your comment We already try it before posting this question and after checking that its not working, the question was and still is how to set it to work?
Yos
Answer by Radoslaw S. · Oct 10, 2017 at 09:44 AM
OK. I'll be glad to help.
What problem do you receive when trying to connect?
Have you configured proxy in the settings?
Thanks for your help in advance
I'm not at the site at the moment and there is a Holiday here in Israel till the end of the week so I have asked prospect to send me any errors from the DTM if there is and will update ASAP.
And yes DTM connected to Mission Control via Proxy right now
Yos
Let's continue with the support team. Please open a ticket.
Learn key aspects on how Dynatrace helps you in your day to day web performance activities. Take a deep dive look into Real User Monitoring and the Synthetic capabilities of Dynatrace.
Thursday, April 26, 2018
Register today!
Register today!
Improve your operational efficiency and collaborate more effectively while addressing tightening security requirements. Have an early taste of what we have cooked up for 2018!
Learn more!
Synthetic script hits test user session limit 2 Answers
Dynatrace Managed Cluster across Azure regions - possible? 1 Answer
Is it possible to set the non auto-detected host name programatically? 2 Answers
Database metrics not available from monitored DB server 3 Answers
Security Gateway usage 2 Answers
