Questions on Backup configuration
raffaele_talari
Inactive
Hi there,
I have a couple of questions about Backups on Dynatrace Managed:
- Is there a Backup API to trigger the backups?
- What is the time format for backup configuration? I guess it's UTC since after performing a backup we discovered this
- Wouldn't it be good to add some details like the following, to avoid confusion?
Raff
Andrzej_Bienkow
Dynatrace Promoter
Dynatrace Promoter
Backups are performed in the server timezone. We will take into account your suggestion to show it. There is no API to trigger backups.
Andrew
