Dynatrace SaaS support for Azure HDInsight ?
shm
Inactive
Does Dynatrace SaaS support HDInsight cluster monitoring? - specifically with "R" as analysis services (as a service - not IaaS)
https://azure.microsoft.com/en-gb/services/hdinsight/
4 REPLIES 4
shm
Inactive
we could possibly experiment with
https://help.dynatrace.com/infrastructure/paas/how-do-i-deploy-oneagent-to-azure-compute-vms/
using cli/ps, with the Linux setup. However i need to know if your "compute" section covers azures HDinsight clusters officially
patrick_thurner
Dynatrace Pro
Dynatrace Pro
Hi Stefan,
we currently do not have dedicated hdinsight support. Nevertheless, deploynet of the oneagent via the vm-extension should work as this is agnostic to higher-level services like hdinsight, servicefabric..
A workaround is to leverage the available hdinsight cluster monitoring and push your required metrics into dynatrace (via api)
We do have hdinsight on our roadmap, still looking for customer use-cases/requirements for monitoring. If you can share them, that would be fantastic.
Thank you
Patrick
Hi Patrick,
hdinsight clusters (as a service) doesnt expose its underlying VM's as actual interactive VM's. I've been able to find the server names via OMS, however the standard CLI/PS doesn't yield any options for applying vm extensions or the like. Could you supply a guide on how to setup the one agent for hdinsight clusters ?
Community Team
Community Team
Azure HDInsight is now supported:
Azure HDInsight monitoring
If you have any questions about the Community, you can contact me at maciej.neumann@dynatrace.com
