Is it possible to simply ping a device?
cyrill_gremaud
Participant
Hello.
I want to know if it is possible to simply perform a ping to a device that does not have OneAgent installed? I don't know if it is possible using a Dynatrace plugin or maybe there is a possibility to create my own plugin to do this?
Thank you in advance
22 REPLIES 22
kristof_renders
Dynatrace Champion
Dynatrace Champion
Hi Cyrill,
At the moment, our plugins run on agents and they can only execute calls locally to where they are running. We are working on a new feature which will allow us to run plugins externally which would then satisfy your use case.
KR,
Kristof
Hi Kristof,
You mentioned some years ago about that Dynatrace is working on a new feature but I'm wondering if any Plugins was created already, we also want to perform availability check on devices where it is not possible to
install oneAgent
Regards
Carlos
I've built a simple ActiveGate plugin to ping devices (measures response time and availability). It creates custom devices. Works quite well for many devices.
Anything you would like to share?
I'll check it within our company if we are allowed to share it.
Hi Julius, I have a case of monitoring some communication devices by ping, it is possible you can share your plugins, I would appreciate it.
AlexanderSommer
Dynatrace Champion
Dynatrace Champion
What is the use case behind the ping? Is this to make an availability check?
Hello. Yes exactly I want to perform availability check on devices where it is not possible to install oneAgent. For example, switches, Access point, NAS, etc.
cyrill_gremaud
Participant
someone has an idea ? @Alexander S. or @Kristof R.
Hi Cyrill,
As I mentioned in my earlier comment, at the moment no external pings can be done with plugins. This is planned for early next year and will allow you to execute plugins towards targets that cannot be instrumented with a OneAgent. In a first iteration this could allow us to have support for known devices such as an F5. Later-on that can be extended.
Cheers,
Kristof
You can also perform the pings outside Dynatrace environment and just send the availability/performance data into Dynatrace using API. More details here:
https://www.dynatrace.com/support/help/dynatrace-api/custom-devices-and-metrics/what-does-the-custom-network-devices-and-metrics-api-provide/
However the execution itself is up to you.
ChadTurner
DynaMight Legend
DynaMight Legend
We actually attend a HOT Day training session where we used a Dynatrace Plugin from an activegate to run Port pings. SO it is possible from within Dynatrace to do pings, we pinged a website, not sure if you can apply the same method to a device
-Chad
Hi @Julius L. Are you able to share the activegate plugin?
Thank you,
Mike
One of our clients has not requested this, for web monitoring we use http monitor, but we want to reach the devices.
Thanks!
Best regards.
Marcelo Santander.
I wrote a blog post which covers this and it has a link to the ping and port extensions from it: https://www.dynatrace.com/news/blog/monitor-your-whole-infrastructure-using-synthetic-monitors/
Mike
Mike
Thanks !
Best Regards!!
Marcelo Santander
AntonioSousa
There is in Dynatrace Hub a synthetic monitor ping that you can use.
Just some additional two cents on this: the extensibility of Dynatrace is very good, and in our case we have even built an extension that pings with 1 second resolution, enabling the possibility of having strong network SLA measuring, in both latency & availability. I'm in the process of trying to solve a dependency issue, to make it available.
Antonio Sousa
Good!!
That is actually the tile from my team for the blog post I linked.
Good luck!
Mike
dietrich_s_knap
Participant
Anyone ever run into the error "Configuration error(Extension doesn't exist on given host)", in spite of the presence of custom.remote.python.thirdparty_ping in the  ../remotepluginmodule/plugin_deployment directory on the ActiveGate selected on the Settings >> Monitoring >> Monitored technologies >> Ping configuration page?
It's usually one of three things (in order of commonality):
1. The package was unzipped incorrectly in the plugin_deployment folder, causing a nested folder structure.
2. The dtuserag (for Linux) does not have access to the files.
3. Another extension on the same ActiveGate has a conflicting dependency. This can be seen in the remote plugin agent log. Splitting it up over two AG's is the easiest fix.
Mike
Mike
You may wish to add dist-info folder conflicts to that list. Once they were removed, the issue I was seeing went away.
