Restart server process oneagent
tarjei_utnes
Organizer
Is there any way of ensuring that you will not have to restart the server processes after, for example a restart of the host itself. Or maybe even if there are new processes being started.
I understand that it has to be this way when you install the agent in an already running system, but what about new services after this point, or as I said after a server / host reboot.
Tomasz_Gajger
Dynatrace Champion
Dynatrace Champion
Hi Tarjei,
Are you referring to a situation where an agent was already installed, but after a reboot deep monitoring is missing and a service has to be restarted in order to bring the instrumentation back?
If yes, then could you provide us with:
  • list of services, for which you have observed this behavior
  • distribution and version of the operating system you are running
  • agent version being used
This seems to me like a service startup dependency problem.
Tomek
