how to show maximum value as a point?
murat_altuntas
Newcomer
Hello All,
Is that possible to show maximum value of specific measure as point in dashboard? You can see the sample picture in attachment below.If it is done, it will be perfect to serve details at the same dashboard.
hayden_miedema
Inactive
Hi Murat,
Yes, you can for several metrics in Dynatrace. Edit the chart in which you wish to show the maximum value, and change the aggregation for the metric:
HTH,
Hayden
