The message you are trying to access is permanently deleted.
28 Nov 2017 05:37 AM - last edited on 14 Feb 2023 10:29 AM by Karolina_Linda
Retention period has been truncated, due to insufficient transaction storage limitation. Customer gets more resources to add storage. But how to add that?
28 Nov 2017 06:01 AM
Hi Miya,
This can be done in the cluster management console for a Dynatrace Managed cluster. Navigate to the environment which you want to increase the storage retention:
It appears you are on the right screen - how much space is left on the node(s) in your cluster? I see you are using 38.13 GB of storage for transaction data - is there anymore allocated in the filesystem you are using for that storage?
Hayden
28 Nov 2017 06:15 AM
Just got the extra 900G storage, so they want to add the Transaction Storage.
28 Nov 2017 06:33 AM
It seems after change the days to 35 Days, the Transaction Storage current value is increasing slowly.
28 Nov 2017 07:28 AM
Yes Mija, that's exactly right. Once you select a higher amount of time for transaction storage it will begin working to build a rolling window for that amount of time. You can also see the current number of days that are being stored on the environment's overview page.
Hope this helps!
Hayden
29 Dec 2017 07:35 AM
Hi, a similar problem is reported. Transaction storage retention period has been truncated for environment Dyna due to insufficient disk quota. Please review Transaction storage settings on environment details page.Our managed server doesn’t show any space crunch.
