Monitoring Gearman
edmund_kueh
Contributor
Hi
Is it possible to monitor Gearman using OneAgent ?
The customer want to monitor certain metrics like Queued Jobs, Running Jobs, Total Workers and %BusyWorkers.
ChadTurner
DynaMight Legend
DynaMight Legend
It looks like Gearman is written in C and C++, which unfortunately isn't supported by OneAgent at this time. Are you able to modify the code of the application or is it an off the shelf app?
https://www.dynatrace.com/support/help/technology-support/supported-technologies-and-versions/
-Chad
