Where does dtagent_bootstrap.js file reside in the web server
skumaresan
Contributor
3 REPLIES 3
florent_duchate
Dynatrace Champion
Dynatrace Champion
Hi
the file doesn't exist as such. It is generated on the fly by the agent.
Regards
Flo
skumaresan
Contributor
Thanks a lot Florent D. The dynatrace agent on the webserver looks for this particular request
"dtagent_bootstrap.js" and generate the dynamic response is it?
correct so it isn't really stored anywhere
