Disable Monitoring
gilles_portier
Dynatrace Helper
Dynatrace Helper
What does exactly do the "Disable Monitoring" feature :
- at the host level ?
- at the process level ?
Here it is written we have to restart the process (https://www.dynatrace.com/support/help/installation) but do we have to reboot the host if we disable monitoring at that level ?
5 REPLIES 5
roman_spitzbart
Dynatrace Champion
Dynatrace Champion
Disabling at the host level will stop all monitoring - at a process level just code level insights for that process. In general if enabling monitoring required a restart of the process, so will disabling.
Hosts do not have to be rebooted for install so you can also remove the agents w/o reboot.
Karolina_Linda
Community Team
Community Team
Fixed the doc link 😉
Keep calm and build Community!
luc_douwen
Newcomer
An extra remark: when disabling monitoring it took 3 hours before the 'used licenses quota' got changed. But we did not have to reboot or restart processes.
We were resetting our trial license (#100) to our eternal license (#50), so we needed to be sure we were effectively using less than 50 licenses. The license change was done without problems.
Good call out. I too have seen that delay in the adjustments to license readings. I wish it was a bit faster.
larry_roberts
DynaMight Champion
DynaMight Champion
I do think the toggles could be titled better. If you are brand new to Dynatrace, it can be confusing to see "Disable Monitoring". I would prefer to see "Disable RUM", etc.
