Resolved! Simple text log monitoring 2528 Views 13 replies 0 kudos log monitoring classic log processing logs
How to link an instrumented mobile/web app to a service instrumented with OTel ? 5 Views 0 replies 0 kudos distributed traces dynatrace sdk oneagent
Resolved! log processing- custom rule 1735 Views 5 replies 0 kudos log monitoring classic log processing
Resolved! Log viewer (Logs Classic) : grepping log 300 Views 7 replies 3 kudos dynatrace managed log monitoring classic log viewer
Resolved! How to extract field from log in Log monitoring V2 6490 Views 11 replies 0 kudos log monitoring classic
Identifying logs that are not ingested programatically 38 Views 2 replies 0 kudos api log analytics logs
Guidelines on organising Active Gate groups for Extensions 2.0 44 Views 2 replies 0 kudos active gate active gate group activegate
Resolved! Where can I browse through my Databases services in the new Databases App? 36 Views 1 replies 1 kudos databases latest dynatrace
A Custom device named Skybox is not being monitored in Dynatrace 20 Views 0 replies 0 kudos custom devices host monitoring technologies
Second MySql database detected with identical host and port but with <unavailable> db name 21 Views 0 replies 0 kudos databases
Failed metric ingestion: java.net.ConnectException: Connection refused (Connection refused) 2856 Views 5 replies 4 kudos installation metrics
Ability to modify background colours to differentiate Dynatrace environments 49 Views 2 replies 0 kudos dynatrace managed dynatrace saas gui
Resolved! Does the new Databases App replace the Oracle DB Insights module? 41 Views 1 replies 1 kudos databases latest dynatrace
Resolved! Who can explain what Built-in process monitoring rule causes below? 142 Views 8 replies 0 kudos oneagent
Resolved! Key requests filtering is not possible with bg-deploy 992 Views 4 replies 0 kudos extensions key requests sap
What is the impact does setting ignoreClusterRuntimeInfo on an ActiveGate have on the OneAgents? 57 Views 2 replies 0 kudos activegate oneagent
Difference between One Agent and Azure Dynatrace Extensions 55 Views 2 replies 0 kudos azure oneagent
Why Doesn't EMS Message Throughput Show Incoming Requests 31 Views 0 replies 0 kudos data explorer queues
Resolved! URL-based sampling vs excluding web request URLs 280 Views 5 replies 0 kudos deep monitoring services web monitoring
