How to disable unwanted services which are not used in application?
vn00506309
Participant
Is there a possibility to turn off monitoring all services not being used by the Application on host box.
I have searched in DT managed portal but couldn't find the option to do this. Could you please advise?
Venkata
Radoslaw_Szulgo
Dynatrace Guru
Dynatrace Guru
Hey Lokesh, please go to Deployment Status page (select from left sidebar menu). There are all host you monitor, and for each you can disable monitoring of process running at host. Hope that helps!
Senior Product Manager,
Dynatrace Managed expert
