Export metrics for User Actions
pahofmann
Is it currently possible to export metrics for specific (key) user actions? I have not found a sufficient metric in the time series API to get the metrics (count / performance value) for a distinct (key) user action.
A customer currently uses appmon dashboards to export data about certain user actions for their SLA management, and wants to continue that in dynatrace.
Have I missed something, or is an API export in that level planned if not existent yet?
Dynatrace Certified Master, AppMon Certified Master - Dynatrace Partner - 360Performance.net
3 REPLIES 3
wolfgang_beer
Dynatrace Leader
Dynatrace Leader
Yes you can find the key user action metrics within the list of timeseries under the names 'appmethods'. See following screenshot of our help page.
Thanks Wolfgang, works like a charm.
TorstenHellwig
Organizer
Hi all, this seems ok with Web applications. Not so with custom/mobile apps - I know I can find them with 'device-application-method' but there is no connection to the (key) user action producing the metric.
Or am I missing something?
Dynatrace Master, Appmon Master
