Dynatrace AppMon and Dyntrace Managed integration with Evolven
jyts_olt
Guide
We would like to integrate Dynatrace AppMon and Dynatrace Managed with Evolven. Has anyone done it before and how was it realized?
Thanks!
Best regards, Jyts
wolfgang_beer
Dynatrace Leader
Dynatrace Leader
As far as I understand Evolven takes multiple different sources of events and alerts from third party systems.
Dynatrace offers quite a flexible way of pushing detected problem alerts into any HTTP REST enabled third party system. Its our generic WebHook mechanism that you can find under: Settings > Integration > Custom Integration.
In case Evolven offers a pull related approach you can also use our Dynatrace API to fetch all relevant information:
Reading correlated problems:
https://www.dynatrace.com/support/help/dynatrace-api/problems/how-do-i-fetch-the-complete-list-of-problems/
Reading events:
https://www.dynatrace.com/support/help/dynatrace-a...
