Changing the log directory
thierry_chea1
Participant
By defaut, the Dynatrace OneAgent logs in the /opt/dynatrace/oneagent/log
How can I change this default behaviour ?
I have found a parameter in the ruxitagentnetwork.conf file and modified like this :
# The path to the directory holding the log files
# Default: <agent location>/../../log
LogfilePath /stor/logs/dynatrace
And then restart the oneagent process :
service oneagent stop
service oneagent start
But the OneAgent still logs in the default directory. Is there another parameter to modify ?
Tomasz_Gajger
Dynatrace Champion
Dynatrace Champion
Hi Thierry,
There is no supported way to change just the location of OneAgent logs. If you need to change the storage location you could use INSTALL_PATH parameter, as described here:
https://www.dynatrace.com/support/help/installatio...
Please let me know if this solution suits you.
Tomasz
