Host monitored on 2 environments
thierry_chea1
Participant
I have currently a host that is shared by 2 environments and I am wondering if it is possible to make this host appear on the 2 environments ? Right now, the host is only appeared on environment "A" because I used the tenant ID associated to this environement.
If it is not possible, I wanted to switch the host monitoring to the environment "B" : is it possible to modify the tenant ID of the OneAgent from the config files or from the web interface or do I have to reinstall the agent with the appropriate tenant ID ?
pahofmann
You will have to reinstall the OneAgent, there is already an enhancement request for this though.
Dynatrace Certified Master, AppMon Certified Master - Dynatrace Partner - 360Performance.net
