[Dynatrace Oneagent] Deploy dynatrace Oneagent in GKE
asruinoiua1
Newcomer
Im trying to deploy Dynatrace Oneagent (latest) in GKE (Google kubernetes engine).
As you know, you can create gke cluster with two option images : choose between Ubuntu or Container OS Optimize (Google). So i have question.
Can i deploy dynatrace oneagent into gke with base os is Container OS Optimize (Google)?
(Of course, with ubuntu, we will deploy successful.)
And for dynatrace team: do you any plan for fix some Vulnerabilities of package like wget, openssl, glib2, zlib in your image? i saw in your image (dynatrace oneagent), have some critical Vulnerabilities.
Thank you so much!
Tomasz_Gajger
Dynatrace Champion
Dynatrace Champion
Hi Duta,
as described on the help pages, Container-Optimized OS is currently not supported. You may want to create a RFE for that.
Regarding your second question, we are aware of the vulnerabilities detected by the security scan. An updated version of oneagent image should be published in a matter of several days.
Tomasz
