Would I be able to pass parameter/option to OneAgent installer if using Windows Group Policy?
waikeat_chan
DynaMight Pro
DynaMight Pro
Some of the servers meant to be installed in infra-only mode, while some servers need their log monitoring disabled. This create few combinations of customer requirement.
Would I be able to address all this requirement if automate the installation by using Wins Group Policy? If yes, I can automate one time only, or have to automate for each different combinations? (i.e if there are 3 combinations of requirement, I have to use windows group policy method 3 times )
Robert_River
Dynatrace Enthusiast
Yes, it is possible to control infra-only mode and log monitoring enabled via command-line.
For the first INFRA_ONLY parameter should be used and for the latter APP_LOG_CONTENT_ACCESS.
See https://www.dynatrace.com/support/help/installati... for details.
To install via Windows Group Policy, please use our MSI installer.
