Dynamically modify dashboards?
scott_brenner
Newcomer
Is it possible to dynamically modify dashboards, or is there any sort of dashboard API?
Example - say I have a dashboard showing the CPU usage of each of my monitored hosts, with one tile per host (I know one tile can show all hosts). If I monitor an additional three hosts, is there a way to dynamically/automatically add tiles showing their CPU usage to my dashboard, instead of having to add the tiles manually through the UI?
edit: Something like this - https://community.dynatrace.com/answers/187257/view.html
Radoslaw_Szulgo
Dynatrace Guru
Dynatrace Guru
That is already available since some time:
https://www.dynatrace.com/support/help/extend-dynatrace/dynatrace-api/configuration-api/dashboards-a...
Senior Product Manager,
Dynatrace Managed expert
