Is it necessary to restart host after disabling Host monitoring?
kohei-saito
Helper
When we disable "Host monitoring" from Settings > Monitoring overview > Hosts tab, is it necessary to restart host after disabling "Host monitoring" or restart only processes?
Best regards,
Kohei
4 REPLIES 4
pahofmann
You need to restart the processes, so the injected agent for the deep application insights is removed.
Dynatrace Certified Master, AppMon Certified Master - Dynatrace Partner - 360Performance.net
hayden_miedema
Inactive
Patrick is right. It is not necessary to restart the whole host, just the processes for which you do not wish to monitor anymore. Restarting the whole host would have the same effect but is not completely necessary.
michael_kopp
Dynatrace Champion
Dynatrace Champion
Actually not even process restart is necessary here. The agents inside the processes will go dormant if you disable monitoring of a host. If you re-enable it, agents that are still injected should also resume monitoring immediately without any restart.
Thanks Michael that's good to know!
