Export Dashboard Output to PDF in Dynatrace SaaS and Managed
rk_sakthiraam
Inactive
Hi All,
Currently we are doing POC on Dynatrace Managed and we would like to know when we will be having the Export to PDF or other formats of dashboard's created in Dynatrace Saas & Managed.Currently we see only option to share. Will this functionality will be brought in near future, if so can anyone help us with some dates.
Thank You
Regards
Sakthi
10 REPLIES 10
thorsten_roth
Dynatrace Champion
Dynatrace Champion
Hi Sakthi,
thanks for your post. Currently we researching in this area. When you talk about a PDF, what do you expect from the result? 1:1 export from the dashboard in the PDF, more details, tables etc.? What is the purpose of the export? Business report? Maybe you can explain in more details your use case(s).
Thorsten
Hi Thorsten,
Good Day & Thanks for your reply!
Currently we have couple of dashboards in Appmon with 5 to 6 dashlets each which includes HTTP 4xx & HTTP 5xx Errors. Java Script Client Errors, Business transaction O/P, Infrastructure metrics.
Even at times people do ask for certain user action purepath report and we are able to export it out from AppMon in Excel or PDF format.
Also , We have such dashboards scheduled to be sent out at X hrs of time everyday
Hope I answered your question and looking forward for your response
Thank You
Regards
Sakthi
Thanks, this helps to understand the use case.
gautier_begin
Advisor
Hello Sakthi,
As we have the same needs, can you vote for me RFE:
https://community.dynatrace.com/spaces/483/dynatrace-product-ideas/idea/191677/rfe-export-dashboard-...
Regards
Hi Gautier,
Done already. Thank You
Regards
Sakthi
Please do me a favor and cross-link this to the above mentioned product idea.
debra_stafford
Newcomer
@Thorsten R. Did this feature ever get added. I would like to have a Overview dashboard I created be in a PDF format so I can share as metrics to my service users.
@Roman W. can you share more insight here?
jmccullough3
Contributor
Has anyone heard about whether this is progressing.  The need to share outside of out customer community who does not have direct access to the Dashboards is important.
Hi @jmccullough3, exporting Dashboards to PDF is already available in the product, check it out:
 https://community.dynatrace.com/t5/Dynatrace-tips/Dashboard-gt-PDF/m-p/202754
The only constant is change. Finding ways for great things to happen!
