Throughput Figure (in per second)
edmund_kueh
Contributor
Hi
Currently the throughput is calculated on a per minute basis. (for ie requests per minute)
Is there a way to have throughput been calculated on a per second basis ? (for ie requests per second)
hayden_miedema
Inactive
There is not within the tool. You could pull the info from the API and divide by 60 if desired.
HTH,
Hayden
