Cluster connection to Mission Control
Yosi_Neuman
HI guys,
When we are talking about a cluster of 3 nodes, customer asks from which of the nodes does he need to open a the link in his FireWalls to Mission Control? all of them? only one?
Thanks in advance
Yos
4 REPLIES 4
marek_kapusto
Dynatrace Helper
Dynatrace Helper
All of the nodes need to have access to Mission Control.
Marek
Hi Marek,
Thanks for the confirmation
Yo
Hi @Marek K.
All the ports in this documentation https://www.dynatrace.com/support/help/setup-and-configuration/dynatrace-managed/configuration/which... must be opened on all the cluster nodes at destination to mission control (in bi-directional) or only some of them ....?
It's no so clear.
thanks fo your help.
Sharing Knowledge
Outbound (section):
URL: https://mcsvc.dynatrace.com or IP addresses: 52.5.224.56, 52.200.165.10, 52.221.165.63, and 13.228.109.33 via HTTPS (port 443)
Kind regards, Frans Stekelenburg                 Certified Dynatrace Associate | measure.works, Dynatrace Partner
