Weblogic state monitoring in Dynatrace
sravan_chandupa
Inactive
weblogic-monitoring.pngHi Team,
We need an alert when the Weblogic state is changed from RUNNING
to FAILED NOT RESTARTABLE,
SHUTDOWN
etc.
Basically the alert should trigger whenever the Weblogic state is
not RUNNING.
Attached the requirement screenshot for reference.
Thanks.
Sravan
Julius_Loman
DynaMight Legend
DynaMight Legend
Basically you need to configure process group setting for the weblogic process group. Just open the process group settings and in "availability monitoring" change the value from "if any service requests are impacted" to "if any process becomes unavailable" . Then Dynatrace will alert you for each weblogic server from the process group if it becomes unavailable.
