Sprint 134 - Change in tagging
kristof_renders
Dynatrace Champion
Dynatrace Champion
At a customer I noticed a change in the UI for tagging:
When I want to filter my hosts based on a tag, in sprint 132, I had the tag application-aem: All
In 134, however, the tag application-aem is also available. This was not the case in 132. So now there are two tags for the same. Is this expected behaviour? Will this "old" tag roll off after a while?
Thanks!
KR,
Kristof
michael_kopp
Dynatrace Champion
Dynatrace Champion
Hi, it should actually be the same tag, but being displayed here twice. this is fixed in a future version. Basically tags can now be key/value or valueless. The new filter control allows both. and yes everything rolls over automatically.
Cheers Mike!
