Dynatrace Azure extension installing using ARM template
Hello!
Has anyone tried to install Dynatrace Azure extension using Azure Resource Management template? What was your experience?
Kind regards,
Guntars
6 REPLIES 6
dexter_lakin
Newcomer
I also would like to know the answer to this please
payam_javid
Participant
payam_javid
Participant
I tried following the Document online, but i keep getting errors, its as if it only works if you are creating a new webapp, but what if i wanted to add DT to an existing one or update the agent?
bkumarpv
Observer
Any updates to this thread with possible experience with Dynatrace Azure extension installing using ARM template?? Karolina Linda
bkumarpv
Observer
Community Team
Community Team
Here are documentation articles on how to integrate OneAgent on Azure App Service using the ARM template:
Automatic install using an ARM template
and on how to integrate OneAgent on Azure Functions App Service plan using the ARM template:
Install Dynatrace OneAgent site extension using an ARM template
Let us know if you need more information or if something is missing from our documentation.
If you have any questions about the Community, you can contact me at maciej.neumann@dynatrace.com
