OneAgent installation SELinux
gautier_begin
Advisor
To install the OneAgent on a RedHat x86 with SELinux with the INSTALL_PATH argument, the installer is requesting the semanage binary. Which packages to install among the yum list bellow:
libsemanage-python.x86_64 : semanage python bindings for libsemanage
libsemanage.x86_64 : SELinux binary policy manipulation library
libsemanage-devel.x86_64 : Header files and libraries used to build
policy manipulation tools
libsemanage-static.x86_64 : Static library used to build policy
manipulation tools
Tomasz_Gajger
Dynatrace Champion
Dynatrace Champion
Hi Gautier,
it should be:
policycoreutils-python
Let me know if this worked for you.
Tomasz
gautier_begin
Advisor
Tomasz,
That's working fine. Thanks.
Regards.
