question
Robert F. avatar image
Robert F. asked ·
Targeted Bosh Install for PCF
Is it possible to do a Bosh deploy of the OneAgent targeting only the Diego cells? This would get us maximum application coverage, targeting the infrastructure that hosts applications, but not all of the ancillary machines.
Dynatrace Managedoneagentdynatrace saascloud foundry
1 Answer
Robert F. answered ·
I Got an Answer outside of the Forums, Adding it here:
Robert, that is definitely possible via the bosh runtime-config. The runtime-config can filter based on both deployment and job type from both an include or exclude perspective. The actual configuration will vary from environment to environment.
(More here: https://bosh.io/docs/runtime-config.html#placement-rules)
Share
