• Forums
    • Public Forums
      • Community Connect
      • Dynatrace
        • Dynatrace Open Q&A
        • AppMon & UEM Open Q&A
        • NAM Open Q&A
        • Enterprise Synthetic Monitoring
      • Synthetic Classic
        • Synthetic Classic Open Q&A
  • Home /
  • Public Forums /
  • Dynatrace /
  • Dynatrace Open Q&A /
avatar image
Question by Arild P. · Jan 29, 2018 at 02:09 PM · oneagent auto-detection request attributes
Capture request parameters in Dynatrace
Hi.
in AppMon it's possible to capture all parameters and attributes from the web requests by enabling capturing in the Servlets Sensor Pack. Is there a way to do the same in Dynatrace?
Regards
Arild
Comment
People who like this
0 Show 0
â–¼
  • Viewable by all users
  • Viewable by moderators
  • Advanced visibility
Up to 10 attachments (including images) can be used with a maximum of 52.4 MB each and 262.1 MB total.
  • Sort:
  • Most voted
  • Newest
  • Oldest
avatar image
Answer by James K. · Jan 29, 2018 at 03:33 PM
The server side service monitoring -> request attributes is where you can capture data like this but if you're specifically asking about capturing all such attributes I don't believe this is possible. I just tried messing with it and it specifically alerts you that wildcards cannot be used if you try to create such a rule. Consider an rfe if you think this might be a useful feature though the alert makes me think there are good reasons for preventing such "capture all" rules.
James
Comment
Arild P.
1 Show 0 · Share
â–¼
avatar image
Answer by Bill D. · Jul 31 at 11:34 PM
This doesn't help at all. I have 100s of attributes that I have been capturing with APM using the wildcard feature, when needed I can then add the specific attributes and remove the wildcard. Most of the time I can leave the wildcard in. It will take me months to find and add all the attributes one at a time. Someone needs to fix this. THIS IS A LOOK FOR ANOTHER PRODUCT LEVEL ISSUE.
Where do we register our displeasure with this decision?
Comment
0 Show 0 · Share
â–¼
avatar image
Answer by David D. · May 31, 2018 at 04:10 AM
If you go into details/purepath/purepath the summary tab acts as the same as right clicking on a purepath node and selecting details. Showing request header information. But I don't think it makes visible anything else as you could in appmon servlet sensor properties using the wild card for Request Attribute, Request parameter etc. This is unfortunate as we would only use the wild card briefly so we could see what was being passed so we can help the app owner who often did not know. Then we could apply that information to make visible only that which was chosen by the app owner. We would immediately turn the wild card off at that point.
Comment
0 Show 0 · Share
â–¼
avatar image
Answer by Satish P. · Mar 04, 2018 at 12:40 AM
we need the ability to capture SQL parameters.. just like Appmon.
Comment
0 Show 0 · Share
â–¼
avatar image
Answer by Ugochukwu N. · Jan 29, 2018 at 05:16 PM
To add to the info James provided, please take a look at the blog posts on how to configure request attributes in Dynatrace
Web requests: https://www.dynatrace.com/blog/request-attributes-...
Java: https://www.dynatrace.com/blog/request-attributes-...
.NET: https://www.dynatrace.com/blog/request-attributes-...
Hope This Helps
NJ
Comment
0 Show 0 · Share
â–¼
Welcome to the
Dynatrace Community Forums
Check out the Community User Guide and First steps in the forum to learn how to get started.
Community Member of the Month
December 2019
Announcing Dynatrace's Community Member of the Month for December 2019, Enrico F.! Click here to read more!
Employee Member of the Month
December 2019
Announcing Dynatrace's Employee Member of the Month for December 2019, Silvia M.! Click here to read more!
Live webinar: Ensuring Digital Business Availability with Dynatrace
Learn how Dynatrace Real User Monitoring automatically detects errors that impact your end users caused by erroneous 3rd party or CDNs.
December 12, 4:00 pm CET / 10:00 am ET
Register here
Register here
Register here
Register here
Follow this Question
Answers Answers and Comments
25 People are following this question.
avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image
Related Questions
Fix my GC and Memory Saturation Problem 0 Answers
How will AI work for problem detection and correlation when manual thresholds are set for CPU, Memory, Response time anomaly detection? 1 Answer
Is it possible to have the One Agent monitoring set to off by default? 3 Answers
monitoring client server application with dynatrace managed 1 Answer
Mapping vCenters/ESX specifically to hosts with DT installed 1 Answer
Forum Tags
mobile monitoring dotnet iis chat kubernetes servicenow amazon web services mysql rest api cassandra dashboard oneagent sdk cmc application monitoring smartscape request attributes monitoring ui developer community user tagging log monitoring services ufo activegate auto-detection high five award webserver uem test automation license web performance monitoring ios migration management zones web services sso notifications host monitoring reports browser monitors java sap vmware maintenance window javascript appmon ai availability tipstricks automation extensions session replay permissions faq documentation problem detection http monitors easytravel network docker tags and metadata cloud foundry google cloud platform synthetic monitoring process groups account usability dynatrace saas gui paas openshift key user actions administration hosts user actions postgresql synthetic locations oneagent security Dynatrace Managed user management python technologies mongodb openstack user session monitoring continuous delivery citrix configuration alerting NGINX action naming linux nam installation database mission control apache mobileapp RUM php azure purepath davis plugins scripting aix nodejs android
  • Forums
  • Public Forums
    • Community Connect
    • Dynatrace
      • NAM Open Q&A
    • Synthetic Classic
