question
Matthew E. avatar image
Matthew E. asked ·
Dynatrace SaaS - Process Group Detection... Is it case sensitive?
I've got a customer that has distinguished different processes based on case sensitivity. i.e. WebServer1, webServer1, Webserver1.
When creating rules for Process Group Detection, is it case sensitive?
process groupssmartscape
1 Answer
James K. avatar image
James K. answered ·
In a quick test it does appear process groups are case sensitive:
Though note that as the name suggests process groups are ideally groups of processes that perform are part of the same logical group so if the goal here is to use process groups to identify individual instances that may not be the best solution.
Also just an opinion - using case to distinguish anything doesn't seem like it would be easy to manage and might cause confusion. Is there any reason this decision was made?
James
2 comments Share
Thanks James for the screenshot! Yeah the client is transitioning from one set of standard naming conventions to another and needed to monitor both. So they are in a transition period.
0 Likes 0 · ·
Ah gotcha - that's reasonable!
0 Likes 0 · ·
Space Topics
mobile monitoring dotnet synthetic monitoring reports iis chat kubernetes servicenow amazon web services mysql mainframe rest api errors cassandra dashboard oneagent sdk cmc application monitoring openkit smartscape request attributes monitoring developer community user tagging log monitoring services ufo syntheticadvisory activegate ip addresses auto-detection high five award oracle hyperion webserver uem usql iib test automation license web performance monitoring ios news migration management zones index ibm mq web services custom event alerts notifications sso host monitoring knowledge sharing reports browser monitors java hybris sap vmware maintenance window user action naming javascript appmon ai synthetic classic availability tipstricks automation extensions diagnostic tools session replay permissions davis assistant faq documentation problem detection http monitors server easytravel apdex aws-quickstart network docker tags and metadata cloud foundry google cloud platform synthetic monitoring process groups account usability dynatrace saas gui paas openshift key user actions administration user actions postgresql synthetic locations oneagent security Dynatrace Managed user management custom python technologies mongodb openstack user session monitoring continuous delivery citrix configuration alerting NGINX action naming linux nam installation masking error reporting database mission control jmeter recorder apache mobileapp RUM php threshold azure purepath davis scripting agent aix nodejs android
