Dynatrace SaaS - User Action to Purepath
matthew_eisengr
Inactive
Can we go from User Sessions, select a session, select an action and then follow that action through a PurePath?
Currently, when I try to do this I get to the point where I can select an action and only have two options: Analyse Javascript Errors or View Waterfall... with no option to view the PurePath data.
How do I tie together RUM sessions to Server Side PurePaths?
rastislav_danis
DynaMight Pro
DynaMight Pro
in waterfall you can filter purepaths and then click on request and select "View Purepath" to dive into specific purepath
Alanata a.s.
