Dynatrace SaaS - Configuration Export via WebAPI
matthew_eisengr
Inactive
I see that we can do quite a bit through the WebAPI and that we can export certain portions of config as found in the Topology and Smartscape section in the documentation: https://www.dynatrace.com/support/help/dynatrace-a...
My questions is... can we export the entire config to include things like custom attributes, process group detection rules, etc. ?
wolfgang_beer
Dynatrace Leader
Dynatrace Leader
An official REST config API is on the way already. I would not use the WebAPI to fetch configs or other information as it it due to change within 2 weeks release cycles.
