Storage requirements for Dynatrace Managed
FranciscoGarcia
Dynatrace Helper
Dynatrace Helper
A customer is setting up a small dynatrace managed server node that they plan to complement with an additional 2. According to the documentation, they would need:
500 Gig for Transactional storage
1.2 Tb for Long Term metrics.
I know Transactional storage is a circular buffer so if you have less space you simply get less retention.
What happens if they install with less space for Long Term Metrics (Cassandra)? (say 600M). Will installation succeed? What happens if they run out of space?
hayden_miedema
Inactive
Hi Fran,
I believe, but cannot say 100%, that the installation will still happen successfully. You may not encounter any problems for some time, but you could run out of LTS space much quicker. There will also be callouts in the UI that show something to the effect of "this node does not meet minimum requirements for a SMALL tier".
Are you saying that the node has only been giving 600 MB for long term storage? If that is the case I would not recommend installing. That will be used up very quickly and data will be lost.
HTH,
Hayden
